tubular k frame
Ed Jackson
Bayoucuda
Bossier City LA
I am looking into purchasing and installing a tubular K frame with all the goodies that go with it. Front suspension, rack & pinion steering, disc brakes, sway bars, the works. Seems like the early A's pose some problems in the area of motor mounts with at least one of the manufacturers. i would like some suggestions on which way to go here along with some pics of some completed projects. i want an alternative to the front motor plate mount, i was hoping for an upgrade, but not a complete race look.
Thanks in advance
Thanks in advance
Contact Carl Gerst at gerstsuspensions.com
Thanks in advance
Send HemiDenny a PM before you buy anything.
check it out here.
HDK Tips & Updates
I've heard good things about RMS, HDK and GTS. From what I've heard, you can't really go wrong with any of them.
i like the magnum force tubular kit, but i would need to fab my own motor mounts off the frame. I would be game if i had an illustration to look at.
RMS with spool mounts is what I run now.
I've also run QA1
Can you send a pick of the k frame and motor mounts
thanks for the help guys, I have decided to go with Hemi Denny! Made the order today, what a great guy to talk to, i am sure he will be solid all the way through, I'll keep you posted
Ed
HDK. Its what i have in my car. I use a lot of different products at my shop. And I chose HDK for my personal car.
I have RMS Alterkation with 13" - 6 piston Wilwoods I installed on my 66 Barracuda and want to sell. It's brand new, just installed to mock-up the back half. I'm changing directions and going with a Strut front. Let me know if you're interested.
you wont be disappointed with the HDK. I love mine, drives and handles great. Did I mention its a 426 Hemi with a flat hood and the correct wheel width.... enjoy
I've got the RMS in my 65. Easy install the only issue is I wish the track width was a bit narrower. Other than that it's sweet.
