racerdude5
Which Fel-Pro head gasket would you guys recommend based on experience? I'm trying to decide between FP 521SD and 8553PT.
And what's the application? Your sprint car?,... or a basic build? Please be more informative: build,usage,head studs or bolts,aluminum or iron heads? Kinda important....
use what comes in a fel pro gasket set for whatever year your engine is, or use whatever gasket has the smaller bore size, being a 318
I'm pretty sure they all are for large bore pistons. Nothing for the smaller 273 or 318.use what comes in a fel pro gasket set for whatever year your engine is, or use whatever gasket has the smaller bore size, being a 318
on felpro blue, no sealer at all!!! just put them on. 8553 requires nothing.So they both seal equally well? Should I use some copper spray seal by Permatex or no?
