Hello, all. A few years back I got a parts stash from a guy that was into the 63-66 Valiant and Barracuda cars. He was buying up stuff to build a 340, 4 speed. 8.75 Valiant convertible. There are some parts in the collection that may or may not be correct for the project.
I have what looks like a 67 and later brake and clutch pedal assembly. It has no rubber pads but the frame "cage" looks almost the same as the A/T setups I have here for the 67-76 models. I am asking if these interchange for all years. The early setups seem to NOT have a recess in the center for the collapsible steering column. Otherwise, they look identical in dimension.
So, the question is....Do the 67 and later pedal assemblies also fit the 63-66 cars?
Thank you.
Thank you.
