To Disable/Enable/Prompt the “Only secure content is displayed” message:
From the start screen, type Internet Options.
Tap or click the Settingsoption below the Search box, and then tap or click Internet Options.
Tap or click the Secruity tab, and then tap or click the Custom Level.
In the Settings box, scroll down to the Miscellaneous section, and under Display mixed content choose from the following options:
Disable, will not display non-secure items. Enable, will always display non-secure items without asking
Prompt, will prompt you when a webpage is using non-secure content
This message is telling you that there may be both secure and non-secure content on the page. Secure and non-secure content, or mixed content, means that a webpage is trying to display elements using both secure (HTTPS/SSL) and non-secure (HTTP) web server connections. This often happens with online stores or financial sites that display images, banners, or scripts that are coming from a server that is not secured. The risk of displaying mixed content is that a non-secure webpage or script might be able to access information from the secure content.
