Trimmed the front and rear glass today and we went for a spin. I do have functioning brake lights (when the running lights aren't on) & hand signals are legal here so it was fairly uneventful.
Very strange electrical issues on this car, now I have brake lights but no signal flashers when the headlamps and parking lights are off. When I turn the switch on I lose a brake light on a random side. The signals have completely stopped working. I still have no instrument lights after replacing the switch (twice) and adding grounds to the cluster.
My gauges all work, and I have power on the orange wire at the "clock" connector behind the gauges. I have even removed the circuit board and checked all the pins for tightness, and they are not shorting to the housing.
When I adjust the dimmer switch my parking lights dim.
I will try replacing the signal cam this week, although I did have all the signals working at various times during the past month.
Oddly enough, swapping to a new electronic flash pot instead of thermal pots made things worse.
Currently at 42 miles on the restomod
