[FOR SALE] 1964 Dodge Dart GT
dirttrackdemon
Active Member
Rating - 0%
0   0   0
I have a southern car I would like to sell. It was originally sold in Sherman, TX then went to Shreveport LA. where it spent its life till it came to the Kansas City area.
The car has all of its original drive line and runs super good The engine was overhauled in Dec. 2014, the trans was cleaned, the bands adjusted and a new filter and fluid installed, the rear differential cover was removed the gear inspected the cover installed and new lube added.
The interior has New carpet, headliner and package tray. The gauges were refurbished and all work correctly.
The front end has all New stuff. Power steering was added as the manual gear was worn out. Power brake booster and dual master cylinder was added. The car is an air car and it works.
I can go on and on but it would be better in I told someone over the phone about the car. Asking $11,250
You need to post price (forum rules)
Is the seat material vinyl? When you installed the brake booster, did you also install disc brakes?
