[WANTED] 1967-69 Dart convertible door panels
Looking at layson's website only the black if you buy the pair. All the other listings say the chrome is not included but available separately.
As for the difference between the dart and barracuda side panels, the dart ones are flat on top whereas the barracuda has a slight curve to it.
The chrome spears are separate and not cheap. The ash tray holes have to be opened up a bit. Only flaw is the holes for the lights are too big. I got some big snap rings to hold them in, but you can only remove them with the panel removed.
I have a used set That need a bit of work. They where on the sight for sale, I think someone with fiberglass skills could get them looking good. I'll send pictures if you want. I'll check if still listed in sale column
They are stIll listed they need a bit of work. (search convertible rear panels dart). Laysons chrome strips are a little shorter than stock I got one at Carlisle last year.
