Super-Cuda
MOPAR .. Move Over, Plymouth Approaching Rapidly!
Hey guys,
I've got a 360 magnum engine,1994, that I picked up for a really good price. Its fully built including aluminum heads, air gap intake etc and its fully balanced and blueprinted .Cast crank is also now internally balanced by adding appropriate weight with a powerforce plus harmonic damper. Here's my dilemma. I am running an a-833 4-speed and I'm not sure what flywheel to use with this engine combo. From everything I've read here it seems that the mopar performance flywheel, part # p5249842 is the one to go with but will it work now that the crank is internally balanced and not externally balanced as it was originally?
Anybody able to help with this one?
