Speedometer
Richard McLaughlin
1974 Duster 340
New Brunswick
hey guy.
Just changed my gears from 3.23 to 3.91. Speedometer way off. Was off in the first place I think.
Anyway of hooking up a digital one? Nothin fancy. Just to stick over the original.
Anyway of powering such a thing off battery? My cigorette lighter does work I don't think
Thanks!
Probably the cheapest way is to get your speedometer rebuilt and then get the right speedo gear that goes in the transmission. The gear would depend on your rear end ratio and tire diameter. Somebody can figure out how to calculate that.
There is nice digital way but it doesn't fit your "nothin fancy" requirement. Get your speedometer rebuilt to go with a Global Positioning System. This can make your speedometer and odometer look very original. The speedometer uses the original face and needle and the odometer is replaced by a small digital display. Unfortunately, I think the whole setup runs about $500 - $600. You could contact Redline Gauge to get more (accurate) info either way you decide to go.
hey guy.
Thanks!
Download Speed box or something similar. Super easy.
Jake
Out fit in Portland Oregon rebuilds speedos , about $90. very nice job. Other then that buy a GPS that shows MPH
In the previous post I discussed the idea of creating a virtual trigger wheel and using the stock MB speedometer sensor. In this post I want to take a look at another potential alternative.
This idea comes courtesy of Patrick Schalles in an article titled How To: Installing a Universal Magnetic Pickup Speedometer Instead of using a MB speedometer he is using a universal speedo e.g. the AutoMeter one.
Instead of using a variable reluctance system he is using a Hall-effect system using magnets instead of "teeth" on the driveshaft. This sensor kit is about $25 from Rostra Precision Controls.
This system uses a different signal but from his article it appears that we might be able to use this signal by putting it through a GM VSS Buffer to convert the AC signal to a square wave signal. I'm not an electrical engineer but it seems plausible that the signal from the VSS Buffer might be able to be fed into the wiring of the MB sensor and get a signal that way. If this is possible, it means that instead of relatively close sensor-to-trigger-wheel gaps we could theoretically go with the easier and more forgiving tunnel mounting and 1/2" recommended gap.
I actually spent about an hour looking for one of these devices at the JY this weekend to no avail.
A follow on solution using this strategy might be to somehow insert the internals of an AutoMeter speedometer into the MB cluster. Probably not something I'd try, but maybe a path for someone to pinneer.
Anyone have any opinions about whether this kind of a signal might be suitable for a direct feed into the MB system?
