That's is a dangerous questionWho here has a 383 stroker engine ? Whats the CI. Do you know the HP ?
LMAO I am a mopar guy. This is a mopar site. The brand X 383 never entered my mind.That's is a dangerous question
DO you mean a 383 BASED stroker?
Or do you mean a brand x 350 stroked to 383 CUI?
Sweet ! I am looking for around 600hp on pump gas. Yea I know, let the coments begin. lolI have a 383 based 448" stroker with 906 heads. Based on 1/4 Mile times, it was about 510 hp at the flywheel. The heads flowed 152@.500 (flowed on a 10" bench). It was a 3.90" stroke with BBC rods. Cam in the motor is a Chet Herbert .480 lift 230@.050 hydraulic. It is the perfect everyday grocery getter combination. It actually had enough torque that it picked up the front tire at the strip. It really impressed the hell out of spectators.
Plenty of Knowledge and Money can get you to 600hp! 65'Sweet ! I am looking for around 600hp on pump gas. Yea I know, let the coments begin. lol
HEADS FLOW 152 @ .500 ?? Dam, I didn`t think any v-8 head would be that bad !I have a 383 based 448" stroker with 906 heads. Based on 1/4 Mile times, it was about 510 hp at the flywheel. The heads flowed 152@.500 (flowed on a 10" bench). It was a 3.90" stroke with BBC rods. Cam in the motor is a Chet Herbert .480 lift 230@.050 hydraulic. It is the perfect everyday grocery getter combination. It actually had enough torque that it picked up the front tire at the strip. It really impressed the hell out of spectators.
Awsome ! That is what I am looking for. Stock looking as much as possible. Pump gas, mid to low 11s, street driven. Maybe I wont need 600 HP but what ever I need ill do. Is there any pictures of the car ?496 I built four years ago is coming back for freshening in the fall. 496, pump gas, solid flat tappet, Stealth heads, made 450hp to the tires, and won 1st (383 4bbl) for stock appearing at Carlisle with factory manifolds and repro exhaust. Without the factory manifolds (headers and bigger exhaust) it's gone up to 470hp to the tires with a Porter Racing custom cam. Using my conversions that's about 550hp at the crank, and he drives it everywhere including long highway trips.
NICE !4.250 crank is the way to fly. I run one in a 400 (511) b body that is a true pump gas streetcar. Runs 10.90's through the mufflers and I drive it to the track. Only real issue with the 383 is you may have to do some unshrouding work at the top of the bore for the intake valve depending on head choice.
That is at 10". Corrected to 28" it is about 254 cfm............HEADS FLOW 152 @ .500 ?? Dam, I didn`t think any v-8 head would be that bad !
Sorry - Customer's car. I don't have any. It's a 70 Challenger RT, 383 auto.
this is the car with the 383 stroker moper built!
sorry, that didn`t sink in! gotta admit, 254 ain`t nothing to brag about. I had a cheap set of sbc heads that flowed more than that .That is at 10". Corrected to 28" it is about 254 cfm............
