67 prostreet gt
Getting pretty old having to drop the driveshaft and coilovers on this car. What are the other big tire ladder bar guys doing for pulling tires.
we ran 16 x32`s for a while on the hemi, had to let the air out of the tires and pry down on the tops of the tire w/ a wooden paddle, while the rear was dangling on the shocks. 66-67 belvedere- fully tubbed.Curious myself.
Interesting idea, I kind of doubt it would be safe or even legal tho.Use bolts instead of wheel studs. Need to have threaded axles though.
Most European cars use bolts instead of studs and nuts, the head of the bolt is tapered like a traditional lug nut.Interesting idea, I kind of doubt it would be safe or even legal tho.
I'm betting you have the required longer wheel studs too - - - - it is what it is - short of cutting the rear quarters to make them "Hemi Dart style" - - I can't even begin to imagine what else you might do.. kinda comes with the territory don't ya knowNo idea on rear end but i habe 15x14 wheels with 7 inches if back spacing
