Engine dyno and chassis dyno.Chassis dyno?
Sorry, I wasn't questioning his or your expertise. I just know that things are different on the street than they are in a dyno cell. I was just trying to help you suss out your minor inconvenience. I'm thinking your idle is a bit much for a stroker with that cam. When I last had my 416 running, it was idling about 750 - 800 with a bigger bumpstick and a Thermoquad.He builds racing engines for Tractor pulling. And sprint car engines.
Cool beans. Post up on this thread when you get her going.Thank you both^^^ Good info. I never liked not having a PCV so im adding one, and will work out the tune when I get that installed. Thanks again^^^
I think the overlap makes it a little rough at Idle more than the lift or duration. But I will be the first to admit I am not really up on all the aspects of how a cam makes power. .Sorry, I wasn't questioning his or your expertise. I just know that things are different on the street than they are in a dyno cell. I was just trying to help you suss out your minor inconvenience. I'm thinking your idle is a bit much for a stroker with that cam. When I last had my 416 running, it was idling about 750 - 800 with a bigger bumpstick and a Thermoquad.
I'm just suggesting that there might be more tuning needed now that you have changed your backpressure.
I will......Again BothCool beans. Post up on this thread when you get her going.
It ran perfect before the Xpipe. Was tuned by the engine builder on the Dyno. Cam is a custom grind, let me find the post
I did have to do some re tuning when I got it home, at sea level, was 1200 ft above sea level at dyno. But got it running perfect.
That is what it is! you are correct and that card is correct. A 408 stroker 411 gears 69 Dart .I just wanna check something. Are you sure that cam card is correct?
Cause I'm seeing a cam with a 102 lobe separation. 247/250 duration at 50. That is a serious cam for a small block. Even a 408 cube small block. Power with a cam like that wouldn't come on until at least 3,000 rpm. Maybe higher? What is this in? I'm also surprised at his recommended stall...
If the cam card is correct then I also have to disagree with moper. A 1000-1200 rpm idle seems in place for a cam like this. Looks a lot like a circle track cam.
He told me that cam would act like a big cam without the problems of a big cam on the street. His own grind design.Street dart? Or drag car?
That would be a heck of a cam on the street. And I'm still surprised at his recommended converter. I mean if I had a cam like that I would think I'd be running a 5k stall converter. Hmm.
But yes. An idle of 1000-1200 sounds right for that lobe separation/duration. That thing must sound nasty. What exhaust did it have before? Just dual? What's it's idle in park, before and after? 1200? And it drops to 1000 in gear? With a large drop like that and that tight converter that would explain the hard engagement. It's a sudden load on the driveline. If the drop was less rpm or the converter looser you wouldn't notice it as much. As for why it idles different now. As others have mentioned it's probably leaner with the new exhaust. The x-pipe is not only more efficient. But also more "spacious", the exhaust gas now has more places to go. Have to talked to the builder and asked him his recommendation?
Yes a street Dart. It does sound nasty. Had duel before, just added the X pipe to get a smoother sounding idle. park 1200 RPM, Goes down to 1000 in drive. I am calling him Monday morning. It is a quick little Dart!
Yes it did. Maybe a 50RPM drop.Yeah the 200 rpm drop is what's causing the hard engagement. It's the load on the driveline that is doing that. So it idled at 1200 in and out of gear before that?
Yes it did.
Thanks for your input. I came up against a 69 396 Malibu yesterday, poor guy never had a chance!Ahh ok. Yeah I imagine it's just the more efficient exhaust. Just have to retune for the x pipe.
that engine is in this.
What throttle/kickdown linkage is that? Beautiful ride!
Thanks. It has a reverse pattern manual valve body. No linkage. Not needed, and every Mopar I own from now on will have this as well. That setup from Mopar is a pain.What throttle/kickdown linkage is that? Beautiful ride!
