Installing Aftermarket temp gauge
PikaPhantom
California
Any fused, switched 12V should be fine. Use the sender that came with it as the sender should match the scaling of the meter.
The only switched stuff in the fuse panel is "accessory" but if you don't mind the gauge being active in that position, that is fine. Maybe the radio circuit
You mentioned the sender you need the one with the gauge. What size is it?
