Heater delete cars had the passenger side vent box. What I did in my 68 Barracuda when I deleted the entire Heater core box, was cut the heater box off of the vent part of the assemble, then added a piece to the side of my vent box to seal it and mounted that. I have an extra one I did if you'd like I can get a picture of it tomorrow.
That would be great I have the heater box and was thinking of do that I was planing on making some doors out of aluminum and getting hinges on it. They are nice to have in summer but sucks in winter with no doors
Usually after it blows a bag of leaves and trash in the car.I call them the "crotch boxes".... Open the doors with a nice loose pair of shorts and you keep the junk cool.... Blows up one leg, and down the other...
Yeo helps get rid of "bagrot"
I bought a drivers side and made an adapter to bolt it to the pass side, can`t tell its not factory, except they both open the same way. don`t know about factory ones tho. small hotrod heater in the center - under the dash.I've had good luck freeing up the hinges by soaking them in rust remover.
Distilled white vinegar, lemon juice and a sprinkle of salt
