694spd
I reinstalled my drive shaft and it appears that it's a little short. I had the slip yoke replaced when I had it balanced. This is the original shaft to the car.
it looks too short to me. But I've seen the results of having a too short driveshaft saw off the back half of a transmission, twice. TF Patty made a mobile out of some of the more recognizable shards of the trans and driveshaft left. It also had a sign integrated with it that asked, "are you sure your driveshaft is long enough?"I reinstalled my driveshaft and it appears that it's a little short. I had the slip yoke replaced when I had it balanced. This is the original shaft to the car.
You cannot tell simply by the picture as you have no idea how long that new slip yoke is. The only way to know is to unbolt the rear u joint and push the shaft all the way forward. With the car weight on the rear suspension (not with the differential hanging on the springs.......is it hanging in the pic?) The shaft should slide forward 1", or have 1" to slide back to seat the u joint.
The springs have more arch than the stock one changing the rear end height pulling on the shaft rearwards a litte.I'm now thinking that the front segments are not 20" long. Maybe more like 21-22" long?
this question reminds me of my wife asking, "do these pants make my butt look big?". If you have to ask, you kinda already know the answer, hahahaI reinstalled my drive shaft and it appears that it's a little short. I had the slip yoke replaced when I had it balanced. This is the original shaft to the car.
That's what she said ...lolYeah, by that picture I'd honestly say your shaft is a little too short.
your top picture is misleading in comparison with his pic, because you have the short, flat rear seal, and OP has the extended "double" seal.Mine looks similar. I thought was short, but inserted it all the way and pulled back an inch and measured. This is what I got from the drive shaft place. There was 1-1/8" of tail shaft hanging out also.
