I am in the final parts procurement for my 72 dart. I need to help getting the proper lines. I am going to use the 11.75 rotors from a 74 e body with pin type calipers.,, I just need some options to for the brake calipers. I would like to mount them from th9999999e rear, but i will not rule out front mounting either. whichever works best
i am going to use a hollow hellwig swaybar need help with with the sway bar links to 72 lower control arms..
any help would be appreciated
