Difference is the thickness of drum face. Just dont step on brakes with drums off. Or you will need wheel cylinders. To me, worth the risk.
A couple things,i would tow slower,but i always do. And if necessary a few stops to check diff and let it cool.
One final alternative, load on dolly backwards,just locking steering would be a challenge. And it may scrub your tires. As toe would be wrong.
