5.9 Magnum/904
JimmyV
MOPAR!!
Spokane Valley WA
Hey Guys,
I have tried pokeing around a little bit in threads but not having much luck...
Anyone have a source and part number for a 5.9 externaly ballanced flexplate that will work with a 904 and converter
any good recomendations for a dampner?
Thanks!
I got mine from B&M through summit racing.
Why can't you use the original Mag flex, elongate the one odd hole, and a neutral converter?
You can, and it works great. You can also buy a symetrical nuetral balance converter and not have to elongate the one hole.
^This
It worked for me.
As for a converter, I went with a neutral balance TCI Streetfighter 2600 stall...
