[FOR SALE] 1969 barracuda survivor
Glenn Wakeman
Tallahassee fl
Rating - 0%
0   0   0
1969 barracuda white (1) owner SURVIVOR. 318 7 1/4 rear 904 trans column shift a/c works power steering bucket seats black interior 51000 mi. New brakes 4 wheel drum new fuel tank,pump and sender waterpump hoses belts thermostat runs drives stops small amount of rust around front and rear windows repair on left quarter probably in the 1970s was carport kept most of its life am/fm radio heard it work once headlights tail brake and turn lights work very clean inside build sheet original title 2 sets of keys also new single exhaust floors are close to perfect drive it on your trailer or put new tires on it and drive it home Tires still look new but probably late 80s Full set of turbine original hub caps no photos yet would like to get 12500.00
Is this car currently titled in your name? How long have you owned it? How many miles have you driven it? Are you confident that with a set of tires that it could make a cross country drive wo/any issues? Interior color? When will photos be added? TIA
I have the original title signed it's been driven 15 -20 mi in my possession 4 years black interior As for cross country man that would be a fun trip I would attempt it with a tow vehicle sharing the trip motor mounts are weak I would change those first as well as all fluids I don't know of any reason mechanically why it wouldn't make the trip. Speedo cable needs some lube Pictures I will take today and try to load them tonight
Pictures attached
