[WANTED] 1965 plymouth valiant transmission gear linkage
Slantsix64
Los Angeles
Im looking for the linkage in the engine bay from the steering column to the transmission to change the gears 1965 plymouth valiant i dont really know what it looks like the car never came with it
Unless it is a standard shift.
OP: Which trans do you have?
Good morning Charrlie_S, it's been awhile to ask you a question :) Can you tell me is the standard three speed on a 66 Valiant is the same as a 65 sir ?
No the 65 has a flange on the output shaft, where the driveshaft connects. A 66 has a slip spline. The 65 trans does not have a syncro on 1st gear. Later trans does (not sure what year that started).
Ok, but is the shifting linkage from my three on the tree work for this member, I have all my shifting linkage still on my 66 Valiant and I need to remove it for my auto transplant, If I am reading this right he is needing the linkage I have ? Thank you again @Charrlie_S
I don't know for sure, as I have never seen the 66 standard linkage, but I think so. I would have to check the parts books. Can do later today, don't have time, now.
Yes except the speedometer cable and the driveshaft are different both changed for 66
Brian
Brian
I was thinking all the hard shifting linkage was the same, I believe the OP here is looking for what I have then .. Thank you Brian
I have an entire 3 spd linkage. Zbar is bad. But I have everything. 65-66s will work. Same linkages.
