[WANTED] Floor shift lower rod
does this help:
Treblig
One more thing, I'm pretty sure the adjusting lever is welded to the torque shaft so you'll have to ask for a torque shaft (not an adjusting lever). If you'll notice in the pic the adjusting lever has two flat pieces of metal. From what I have seen the year of the car determines whether there are one or two pieces of metal on the adjusting lever. I know for sure that the 68/69 uses the single piece of metal, but I'm not sure about the 67 and earlier??
Someone will surely let you know??
treblig
If someone could provide you wit the exact length between the centers of the pins, it looks like it would be pretty easy to fabricate, if you have trouble finding one.
