justme
Does anyone know how much to shorten the steering shaft when putting in a stock box ?
What I did was get a shaft from a car with a collapsing steering column . You can slide it to any length you need. Worked on my B body but will probably work with what ever you are building.Does anyone know how much to shorten the steering shaft when putting in a stock box ?
