[SOLD] Bolt-in A-body Ford 9" rear end with axles. $400
Pabuhr
Iowa
I have a Ford 9" housing that was narrowed to 52" overall length with 43" perches. Work was done professionally with quality welds. Includes aftermarket axles with Mopar 5X4.5" bolt pattern. New bearings on axles. The rear end was never used after being set up. 31 spline axles. 3" axle tubes.
Located in N.E. Iowa.
$400.00.
Can ship on a pallet if needed.
If had 4" axles, do it in a heartbeat... Are you sure it's not. Usually with multiple holes,a 4" bolt pattern is possible.
Most aftermarket axles use the common 4.5 - 4.75 - 5" bolt circles. It is not a 4".
