When you do install them, consider the Moog "improved" strut-rod bushings. They are much easier to install and don't have the "sheet-metal cuts thru rubber" problem. Cost is nominal. See rockauto. I also vaguely recall seeing after-market strut rods which are adjustable to allow more caster for today's radial tires.
