What's this trans crossmember for?
meathead66
Mod Top
Tinley Park Illinois
Can someone tell me what this crossmember is for? I need one for my 69 Dart with BB 727.
Will this fit and which mount would I need? Kinda think this one won't do. Everything is out of the car so I can't test fit. The bolt holes line up but it just don't look right. Thanks
It's been modified with that plate welded to the top, making it a solid mount
I give up. A transmission?
Probably will break the tail shaft housing.
Even when I ran solid motor mounts I used a rubber trans mount.
Just cut off the homemade solid plate and reuse it with a rubber mount. My guess unmodified is 67-72 crossmember.
Looks like my 66 Valiant cross member, yes ! a must to replace the rubber mount
