jonn6464
1970 Duster
I'm installing front disc brakes on my 1970 Duster, but unsure which spindle goes on drivers and which on passenger side. The box arrived without any indication of LH & RH.
I'm assuming the pic below is for the drivers side... is that correct?
Also, neither spindle would match up to the MOOG lower ball joint arms that I bought. They are for 1970 year model. Will the 1973 ball joint arms be okay to use with my 1970 steering center link? I believe the 73 ball joints will work with the spindles I have.
Thanks for the help FABO.
