1963-64 Tail lights
No, I bought directly from David A. I never, ever, ever buy from Layson. For the reasons why, see (for just a few examples) here, here, here, here, here, here, here, here, here, here, here, here, and here.
Wow! Just having read some of those examples posted by SlantSixDan makes me feel very lucky that I received anything at all from Layson's, especially since I live in Australia, with no chance of turning up on their doorstep to complain.
I sent him an email, asking if they had any on hand. He told me to check with layson's first and then get back to him if they are out of stock. Is that what you had to do?
This comment leads me to believe the lenses sold by Layson's are the same lenses manufactured by DAMAX, correct me if I am wrong. If this is correct, check the photos I posted earlier. While the lenses are OK, the outer chrome rings do not fit well. The solution is to CAREFULLY remove the chrome ring, drill larger holes in the lens, glue the rings back on with Araldite...
While the revival of this thread has been informative, the OP has not popped back up with it, so...@NodakDuster , and that's not lighting up as an alert link.........................
Last seen July last year.........................
I am not looking to get rich. He has the equipment and ability to help me and I thought it would be fun to give it a try. I have a set of 63 and am going to try and drum up a 64 light.
Just saw your post
Did you get setup to make the 64 taillights? If so how much $ ?
