B batoven Well-Known Member Joined Jan 15, 2015 Messages 63 Reaction score 12 Location Washington State Jan 24, 2018 #1 Will a B body 904 auto fit in an A body with no modifications? I thought I read somewhere that the tail shaft/housing is longer on a B body 904?
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,925 Location 92201 Jan 24, 2018 #2 Same transmission. You are thinking 4 speeds with different tailshafts.
Sedanman 67-9 Valiant specialist Joined Apr 3, 2009 Messages 8,536 Reaction score 593 Location chicago Il Jan 24, 2018 #3 67 and older use a different converter than 68 and up so keep that in mind.
MRGTX Well-Known Member Joined Sep 24, 2007 Messages 2,198 Reaction score 728 Location CT, USA Jan 24, 2018 #4 Obviously irrelevant in the A904 discussion but I believe that the bell housing for big block vs small block would be a consideration if you were looking at 727s.
