Try this... remove the winder handle to expose the splined drive stud. Use a block of wood and a hammer to jar it in every direction. You would think there's just a bearing there. Its a multi part, almost clutch like, assembly. Inside that is where they can seize up with rust. I've had to rebuild them with parts robbed from a donor regulator.
