Temperature sending unit problem.
Here is the old and new units together. The old unit is the only one that has any sealant on it I can tell. The arrows point to where it looks like there is sealant on it. Some of you are saying it’s my gauges. Like I said the gauge just sits at C with the new unit.
Have you verified continuity and near-zero resistance between the two ends of the wire that runs from the sender to the gauge?
I will bet the cost of the sender that the problem is NOT the sender.
I ground the temperature sending wire on the alternator and the gauge will jump up to hot but fairly slowly.
This is normal, thermal gauges react slowly
And once I take it off of the ground it falls slowly back down to cold
This is normal thermal gauges react slowly
and then goes below cold and sometimes points below the dash.
This is NOT normal.
When I have it connected to the temperature sending unit it just sits below or at cold.
This is NOT normal if the car is at temperature
I believe it has been stated that the gauge and OE sender worked fine. Then had an issue that the sender did not fix.
If the fuel gauge is functioning correctly that suggests the dash voltage regulator is good.
If no other changes were done to the car between working and not working it is the gauge.
Just my 2 cents.
Could it be that I just got the wrong sender? Slantsixdan suggest this https://www.amazon.com/dp/B000C81UZY/?tag=2402507-20. The new one I put in was a duralast TU22. It came with no red tape on it. The picture is exactly the way it looks. The one slantsixdan suggested has no tape covering on it either. I have been told that if it doesn’t have any tape on it it will not function properly. The gauge obviously works to a certain extent otherwise it wouldn’t move at all when I grounded it. I don’t have a mopar c-3826 tester to test the gauges. I really do not want to pull out the dash to test this because I’m afraid I’ll never get it back together right. I’m really kind of clueless at this point. I have a connection when I test the battery ground and the sending wire so I’ve ruled out bad wire.
Could be.
Duralast = generally garbage.
May or may not be nominally correct for the application. If so, may or may not have the correct resistance range.
That doesn't matter.
That's not correct.
Odds are very good that your options are to pull the dash and fix it, or leave it unfixed. This is part of what goes with driving an old car: you eventually have to fix stuff most drivers never have to think about.
How come? Instrument cluster removal and installation isn't terribly difficult.
No, you aren't; you've been given lots of good clues here in this thread. Now you just have to choose to pluck up your courage and follow them.
No, you haven't. You need to make sure there's no significant resistance in the entire length(!) of the wire that runs from the sender to the gauge. That means pulling the instrument cluster.
Go on ebay and buy one 75ohm 2 watt resister, one 25 ohm 2 watt resistor , and one 10 ohm 2 watt resustor. You now have a mopar c-3826 tester. Take the 75 ohm and connect it between ground and the wire that would connect to the temp sensor . What does your gauge do?. Do the same for the other residtors. Record the results and report back
He says:
129 ±10% ohms at 100°F
17.7 ±6% ohms at 220°F
11.8 ±5% ohms at 250°F
Ok! Thanks. I’ve been looking at the wiring running to the temperature sending unit and noticed that some of the insulation is burned off. I think the wire is being grounded somewhere it isn’t supposed to be so I’m replacing the wire and seeing if the fixes anything.
if the wire was grounded the gauge would peg ( you knew that ). If it stayed grounded long enough, that would damage the gauge. I've seen this wire pinched under the slant 6 valve cover and damaged badly. If most of the wires strands were broken, that might cause your symptom.
