Is there any way to locate swaybar tabs on LCAs while they are off the car? Lots easier to weld them on while standing up rather than laying on the garage floor...
I’m looking at a modest priced HellwigWhat Anti Sway bar are you using?
This will be for my 74 Duster stock V8 K memberGot to know the part number of the bar you’re looking at and the year of your K member. Hellwig makes three different front bars for the 67-72 K and one for the 73+ K. Two of the 67-72 bars use the stock tab locations (one hollow bar, one solid) and the other uses a custom location to allow for wider front tires. The 73+ bar uses the stock 73+ tab location.
Hellwig Motorsports Tubular Sway Bars 55905
Oh ok. That one uses the stock 73-76 LCA tab locations. I can pull some measurements off my stock LCA’s tomorrow for you.
For a "Stock" anti-sway bar.....
I put a hellwig tube bar on my duster like 10 years ago that I swear used the shock bolts to mount the tabs. I don't remember welding tabs on for it. Looking at how far off those would be from the stock tabs I wonder if it's a different bar.
I take that back I went out and looked it's a bolt on tab if you don't have the stock tabs.
I have a 67 barracuda with a 67 k member and am thinking of using factory tabbed '73 lower control arms for an aftermarket sway bar...is that a problem?
I haven't ordered the sway bar yet...perhaps I should just use my 67 lca's and weld on tabs...?
That doesn't work. Your pre 73 K member is closed cavity. The stabilizer bar routed around the front outside of it. Those OEM end link tabs were farther forward, closer to lower ball joint. Longer end link kits too.I have a 67 barracuda with a 67 k member and am thinking of using factory tabbed '73 lower control arms for an aftermarket sway bar...is that a problem?
Can you snap a pic of that bolt on tab please?
