73 Dart 360 Transmission Options?
Cley/All,
How bad does the tunnel need to be modified? Can that be done with the engine in the car? Are we talking some cutting or bashing in a area?
Marion
It's not that bad, the transmissions are largely the same shape except for the OD ones are a bit bigger in the rear due to the extra set of gears. From what I've seen you just have to cut the reinforcement bar from the tunnel of the floor pan and make it thinner by welding a thicker plate directly to the floor. I'll dig around for the thread on here real quick.
Edit: here's the A500 swap thread I read when I was researching it to see what it took: 42RH / A-500 in a Duster with pictures.
