318 to 440 conversion 69 fastback
peterOZ
Sydney - Australia
Can someone please point me in the right direction if this mod has been already covered.
Were can i buy parts needed to convert 318 fastback barracuda to 440.
What else is needed to be replaced or modified to make it fit.
Thanks.
might want to check out bigblockdart.com
Auto.
Could the conversion allow either 904 or 727 to be fitted ? If so , would floor need to be touched if fitting 727?
no 904 will bolt up to a BB motor, you will need a BB 727 transmission
Schumacher engine mounts
Big Block 727 transmission
correct radiator the inlets/outlets will probably be on different sides for the big block
No need to touch the floor or seam for a big block 727. Certain exhaust systems might fit better with the seam hammered flat.
