65wgn440
Do not tighten the shackle nuts until the suspension is fully loaded (sitting on the ground after suspension had been jounced a few times). Front spring eye also, although with rear of car jacked up under diff, front can be tightened easier and still be ok. Still use jackstands to be safe, just not quite contacting axle tubes.
