Hood insulation pad
fnabody
Were 1970 Dodge Dart Swinger 340 cars equipped with a hood pad from the factory?
Does your cars hood have the receiving holes for the clips all along the support structure .. Like 16 total 1/4 holes .?
I'm pretty sure they came factory bro.
If it came with A/C then yes for sure. All hoods I've seen have the receiving holes. They were all stamped the same.
Thanks. The pad will have to have two holes cut into it for the two fresh air holes under the twin scoops.
Just to let you know the aftermarket ones are thicker than the factory ones were.
The J55 Undercoating option included the hood insulation pad. They were not a standard item.
Good info. My car is a factory a/c car. No J55 on tag and broadcast sheet is mia.
