dadodgekid
When in doubt... floor it
Does anyone have these on your a-body and run a 275/60 with a 10” wide wheel? Specifically drag racing?
hundreds have and do, it`s what they were designed for , so guys could run bigger slicks.Anyone drag race with these?
71’ scamp is the car im referring to. I dont want to cut the frame rails, so i started looking at the 3/4in offset hanger kits. Im putting a different rear under the car, so moving the spring perches was in my plan anywho. Ive got the wheel and tire from my other cars to use, thats why i want to use the 15x10 and that tire.
Not to get into a pissing contest ( plus I’m heading out the door to the Social Distortion show) but most drag radials are good mounted on 10 inch wheels...
A GREE W/ THE ABOVE INFO^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^That’s fine if you just want to run drag radials I guess. I just assumed he actually wanted to run street tires.
And either way the quarter clearance would be better on a slightly narrower rim. Depending on the actual dimensions of the OP’s factory wheel tubs he might need that extra little bit of clearance.
