AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,900
- Reaction score
- 12,255
Speaking of 5.9s and Durangos,What kind real-world fuel mileage do those brutes get? I really like the looks of the first-gens
My Durango is a 2wd and got between 17 - 18 mpg on a 40 mile round trip commute to work at 60 mph. My 3/4 ton Ram 2wd gets the exact same.Speaking of 5.9s and Durangos,What kind real-world fuel mileage do those brutes get? I really like the looks of the first-gens
Well that doesn't sound so bad; 17US would be 21 Imp,I could live with that. That's only 3 less than my wife's Honda PilotMy Durango is a 2wd and got between 17 - 18 mpg on a 40 mile round trip commute to work at 60 mph. My 3/4 ton Ram 2wd gets the exact same.
I can get 16 to 17 out of ours.Speaking of 5.9s and Durangos,What kind real-world fuel mileage do those brutes get? I really like the looks of the first-gens
Any idea how to diet that beast down to ~3400#?,lolI can get 16 to 17 out of ours.
Dany gets about 10.....lol
It's a 4x4 with 180k miles on it.
Put the motor in my Barracuda???Any idea how to diet that beast down to ~3400#?,lol
Has anyone ran their stock 5.9 magnum efi at the drag strip?
What rpm did you turn with this engine safely?My 67 Dart 3270 lbs, 300hp 5.9 Magnum crate, summit cheapo headers, 904/3.91 650dp ran 12.5-12.7 The OEM stock cam was done at 5500 rpm. Upgraded to home ported heads, chinese air gap, lunati 235@.050 .495 lift hyd roller 11.86-12.0 A well tuned EFI should run the same.
6k. I eventually had #8 exhaust valve break off and blew this motor. Hyper piston shattered and this motor is in the scrap pile. Back to running a 340 with shaft rockers for me.What rpm did you turn with this engine safely?
Mopar action did an article 6-7 years ago with a 62 savoy. Stock 5.9 with tti headers and exhaust. Not sure of the gear. It was tuned by a Chrysler engineer. Ran low 13’s I believe. I’m gonna try to find the article
i haven't done the EFI magnum, but I'd expect 13's with gears in the 2.xx's
With 3.91's and headers, I'd say 12's
105 mph should be much faster than 13.5. I'd expect a stock magnum would outrun my stock LA 360 and it went 13.9 with 2.45 gears/no headers.My experience with a stock 300hp Magnum says that this is pretty optimistic. Even basic 1/4 mile calculators would put a 3200lb car at 13.5/105mph trap speed. That Savoy must be a few hundred lbs more making "low 13s" on 300hp impossible unless it started from a 10mph roll.
No posi ( poke a few ). added 4bbl, used a less lift/duration cam than a factory 360 4bbl. that's it. Car weighs 3240 if I remember correctlyIn any case, 13.9 is a very respectable time for a stock 360. What's the setup for your car running this 360? Do you have a limited slip?
you don't think the 2.45 gears were helpful??? LOL. 97-98 mphA 3240lb car running a 13.9 ET would have to make about 275 crank horsepower which is believable...that final drive ratio was probably not helpful and with the lack of posi, this must mean that you can really drive. What was your trap speed?
98 Dakota R/T nothing but drag radials and a K&N air filter run 14.91
That’s enough MPH to be in the 14’s.Best I could do was 15.68 et @93mph. Thought it would do better, car feels faster than that
