Bulldozer
free ice cream sandwiches
74 charger , seat belt thing has been bypassed. trying to get 12v out of the ignition wires at the ballast connectors for a GM module. the blue wire has just about 12v in the run position , the brown about the same in crank position, but when I jumper them together , the voltage drops to around 7.5-8v . is this a short or huge draw in the switch or another possibility? or is this normal ?
also , if I connect the blue/brown together and hook them up at the + on the coil and disconnect the brown wire from the ballast connector, it sparks and I get 12v again.
thanks
thanks
