I think the seat looks better than the basic rear seat. Cross bracing can be modified and if I mini tub the rear for a bit more meat, fabrication would be needed anyways.Why would you want to do this? Even if it folds down, there is all that cross bracing blocking access to the trunk. But I don't think it would fit -- it's narrower, and the rigid back would be too thick. And how would you deal with the package shelf?
May have to look into that. ThanksLike I said you can use everything from a duster fold down seat (looks like a barracuda fatback one) from the speaker panel to the side panels(braces) to the brackets and the seat will fit and look correct.
