daliant
Befuddled
That looks like a Ford/Sterling 10.25 rear.I just saw this a couple miles from here. Dana 60 from a truck. $100
Would that be a good place to start. Shorten to length, new perches, axles etc.
NEGATIVE...built CORRECTLY the 8 3/4 will hold up to some serious power more then a few 9 second cars using them..as for the "bullet proof" dana 60 seen more then a few "grenade" at the track..
I get it. But the cost is the same so why bother with the 8.75? I'm going to ditch my 8.75 and do a Dana. It makes no sense to build an 8.75 when you have nothing to start with.
But the 8 3/4 is easy peasy to do a gear change in. So unless your car is a dedicated drag car AND already sorted out the 8.75 makes a lot of cents...
What do you consider built correctly.NEGATIVE...built CORRECTLY the 8 3/4 will hold up to some serious power more then a few 9 second cars using them..as for the "bullet proof" dana 60 seen more then a few "grenade" at the track..
I've heard this argument too. It comes from guys who never tried to swap third members on a regular basis. It doesn't happen very often.
I used to change mine more often than my underwear...lol
once drove to Spokane for a race running 2.90s (?) then swapped in 4.11s to run....then back to the 2.90s...
Did the same for a trip to MN to race BIR.... and Seattle...and Woodburn...
I hear that we use to drive down to E-town with highway gears get to the hotel and spend the afternoon swapping out chucks go racing for the weekend then swap back before heading home,had it down to about 20 minutes per swap..
There is a strange s60 video on YouTube and they claim that because they have gone to a threaded adjuster for setting the backlash that if you already know your shim pack thicknesses you can swap Dana 60 ratios in under an hour. And the Dana is superior in strength to boot.I hear that we use to drive down to E-town with highway gears get to the hotel and spend the afternoon swapping out chucks go racing for the weekend then swap back before heading home,had it down to about 20 minutes per swap..
I had an 8 1/4 under my dart with Mopar 4:56 gears that you used to be able to get from Chrysler. Even had an 833 stick shift with it.I have the 8.8 but if I had it to do all over again I would have just left the 8 1/4 in it. I don’t race it much just a couple times a year. I have gone from 7 1/4 to 8 1/4 to b body 8 3/4 to 8.8. Got my money back every time but not my time. Do your research stick to your plan Don’t wait to upgrade save and do it all at once.
Like I said... if you are running a high horse dedicated drag car or have settled into a permanent build for your street car then the Dana is a better way to go. But fore some of us that might run the 1/4 on occasion and will take our cars on longer journeys the 8.75 is a good choice.
When Im not curling 8.75 pigs I am playing hockey. And when Im not playing hockey Im drinking beer.....lolYou must be under 30. Or a fitness nut. Or both. I don't work that hard any more.
So, you are a fitness nut. Now I get it.
