[WANTED] 5.9 magnum camshaft
I have a stock 5.9 cam. No idea on the mileage though. 5.2 magnums have a better cam then a 5.9 I think. Would be easy to find a used 5.2 cam
Sorry to interrupt. I have a question about the 5.2 mag cam versus the 5.9 mag. Is there really much difference in them to warrant swapping them? Anybody have the specs. My motors are 95 5.2 and a 98 5.9. Thanks. Kim
For f.i. stock intake ,f.i manifold O.B.D 1/2 : Slightest improved, Kimmer..
Pick your cam ,in carb land....
5.2 .432 lift 250ºint 264ºex 31ºol
5.9 .410. 274. 264. 36.5
Info from 97 Dodge truck manual.
This is what I have, which is pretty close to what was already posted-
5.2 Magnum Hydraulic Roller 432/432 251/264 113CL
5.9 Magnum Hydraulic Roller 410/417 249/269 109CL
If not found call Oregon cams...
+1 360-256-7985......
Thanks. I called them and I'm, getting a stock grind for very cheap. Sounds like you have to change springs and maybe get the computer modified for an rv cam. Oregon Cams did not tell me this, I got it online. Thanks again.
What are you gitting for how much money?
Nice work,Dirtwagon Holmes . Very nice ,information.
How is the last ebay cam linked a choppy idle 9:1 plus cam with .0.5 of 218/228 and lift of .492 on a 112?
That Lunati cam I posted doesn't even say that.
Always thought the choppy idle got down to how much overlap you had.
I have a brand new crane cams cam for the magnum.. its .512 lift.. I can go get the cam card and take a pic of it if you're interested..
