photo request brake lines
torred0319
68 valiant installing new brake lines confused where proportioning valve mounts and line routing to master any one have photo? rear drum front disc manual brake
I made this diagram, when I did my 73 duster.
This is the factory assembly out of my 67 Barracuda.
The clipped line at the top is the front right (you can see the line running through the tool box)
The missing line is the rear.
Alan
The distribution block Alan shows was the same as used in your '68.
It mounts to the frame rail below the master cylinder.
On your car is equiped with disk brakes, there will be a proportioning valve a few inches further back. It looks a little bit like the state of Texas. Illustrated a couple places in here.
1967 Chrysler Imperial Disc Brake System From the Master Technicians Service Conference Session 233
also note there's TSB for bleeding brakes with the then new dual master cyl.
The 1970 Hamtramck Registry "1967 DODGE MODEL TSBs Index" Page
On the propotioning valve, there's a metal band wrapped around it as the bracket to hold it to the rail. People have posted the in and out line nuts are different sizes. If so, the orientation should be easy to figure out. (I'm using an aftermarket one so can't verify that, but it seems correct).
