RJG
Hello All in FABO,
I have finally removed damaged clutch out of my '65 Barracuda. Found damaged throw-out bearing and 3 damaged springs on the clutch plate.) Now, the question is:
"What would be a good clutch to use for this Barracuda with a 360 (.03 over), very aggressive cam, and a Hurst 4-speed manual Trans.
After building the car for road racing, the previous owner had replaced the heavy clutch to try and make the car less difficult to drive. But the clutch never seemed to be strong enough for the engine. And then it broke.
While it is very powerful and fast, I do not race the car. It is a weekend driver (being in SoCal, I punch it when I can), so a strong clutch that can handle the engine but not be too difficult on SoCal Freeway conditions and local driving.
Any suggestions?
And, thank you again for the input and advice on getting the trans out of the car.
rjg
Any suggestions?
rjg
