jonnyrose Well-Known Member Joined Aug 30, 2017 Messages 227 Reaction score 89 Location canada Oct 19, 2018 #1 im missing somthing,where do i get a trim lock or bead lock,my 68 2dr sedan ,is for a 67-76 2-4drsedan,any recomondations,on what sealent i should use between the seal and car
Steven190 Well-Known Member Joined Jan 13, 2012 Messages 1,250 Reaction score 655 Location Omaha Oct 19, 2018 #2 I found that the AMD supplied gasket worked the best, built in lock. I did not use any sealant, It should seal without. Good Luck
