[FOR SALE] 5 and Dime garage sale
pishta
I know I'm right....
Tustin, CA
almost everything $5 or $10, shipping is on you. I always ship cheapest. Ill estimate shipping but itll probably be more than the part at these prices. Big stuff will be more expensive to ship naturally.
SOLD>>>1.88/1.60 valve set, serviceable. plus spares $5 <<<
B/RB double lower pulley cut from a quad. 2" deep pulleys at 1-1/4 and 1-3/4 $5
A triple lower symmetrical bolts 3-3/4 deep pulleys at 1-7/8, 2-5/8, 3-3/8 $5
water pump pulleys single 1-3/4 and double 2-3/4 deep $5
slant fuel pump with boost ref spud almost new. $5
oil pick up tubes $5
Edelbrock 'Elite' line push on breather $5
Slant bracket $5
>>>sold cam plates and eccentric w/bolt $5/lot
large slanty air cleaner ~15" $10
blue balancer with MP tape (neutral balance has TDC at keyway) $10 (black sold)
Not shown: big Gear reduction starter $10
SOLD>>>GMC carb hat: cut for holley carb, needs spacer to seal, has 3" reducer on it and hole for BOV. unique piece for sure, was on my blow through slant with a 350 2bbl. $20
I try and ship flat rate unless its cheaper to send priority so if it fits in any flat rate box, thats the max youll pay for shipping. Dont flood me with shipping quotes, just use your own judgment and ask if its worth it. Paypal only. Losing money on all this stuff, just want to pass it on.
I will take the fuel pump eccentric & Bolt please. Any chance you have a oil drip tab as well?
Thanks Mike I'm only 30 min away from you!
