Cuda Al
The only way to move the vent frame up is to move the front of the door up.The backend of the passenger glas is snug to the top.........About 4" and the vent window frame need to go up.
Alan
Thank you. i noticed the same door is hitting the striker pin alittle.The only way to move the vent frame up is to move the front of the door up.
Alan
ahhh nope they are different. The hardtop dart,valiant and barracuda and fastbacks have a sharp tip Vs the dart valiant/barracuda convertible. Vent glass is the same on all models even the 4door and post cars. even the steel(except post and 4 door which are the same), but the chrome pot metal is different along with the rubber cushion on the tip (i used to work at McGraw glass that made the glass for 35 years) convertible is on the bottom hardtop on the top.The vent frames are all the same, Dart/Barracuda hardtop/convertible/Fastback
If I recall there are no adjustments on the frame. I had an alignment issue and looked.
The only thing you can try is to loosen the bolt at the front and the bottom and see if rotating the frame will help, you will not get any lift out of it, that is fixed.
The door may be out of alignment, maybe it needs to be lifted.
Alan
Wrong, That may be true for the 1st get but not the 67+ahhh nope they are different. The hardtop dart,valiant and barracuda and fastbacks have a sharp tip Vs the dart valiant/barracuda convertible. Vent glass is the same on all models even the 4door and post cars. even the steel(except post and 4 door which are the same), but the chrome pot metal is different along with the rubber cushion on the tip (i used to work at McGraw glass that made the glass for 35 years) convertible is on the bottom hardtop on the top.
Per the 67 parts book they are the same (I assume 69 is the same)
Alan
Was repainted years ago by previous owner. I bought new hinge pins and bushings. The problem door does slightly hit the door striker pin. Any idea on how to raise the door and hinges to raise it up?I still think this is a door alignment issue. The back of the door looks to be down an 1/8" or so.
With the door hinges forward of the top of the vent window any amount of sag in the door will be noticed there.
Your hinges may be worn or the door just needs alignment.
Was this car repainted? Have the doors been off?
Alan
I don't recall if you can get to the bolts with the fenders on the car. The alignment in issue here is the bolts that hold the hinge to the body.Was repainted years ago by previous owner. I bought new hinge pins and bushings. The problem door does slightly hit the door striker pin. Any idea on how to raise the door and hinges to raise it up?
Roger that great info. THXLooking at this again, its seems your top is out of alignment, not the glass. Look at update pic #5 and compare that to update pic #6. You should note that on the left side glass the stainless windshield moulding is pointing straight back, with about a 2" gap, to the stainless w/s moulding/ retainer. Not so on the right side. On the right side, the windshield stainless and the w/s stainless are out of alignment. The w/s and stainless attached to your top need to be adjusted to your glass. Close the gap with the top.
THx........ Yes window glass seats into the top of the vent window frame. I thought if the vent window frame could go higher that would help the window. I did notice my upper door hinge has a goughe on the s metal catch in the hinge. Mt door hits the jamb post. I bought a replacement lower hinge to see if it helps. I'll do that in the spring.Ok I'm reading the initial post again.
With the door open is the door glass going to the top of the frame?
When rolled up the top of the glass should be flush with the top of the frame.
If not the up stop may need adjustment.
If it is and you still have a gap that is most likely a door adjustment.
Alan
Yes. My vent frame tops are flat.ahhh nope they are different. The hardtop dart,valiant and barracuda and fastbacks have a sharp tip Vs the dart valiant/barracuda convertible. Vent glass is the same on all models even the 4door and post cars. even the steel(except post and 4 door which are the same), but the chrome pot metal is different along with the rubber cushion on the tip (i used to work at McGraw glass that made the glass for 35 years) convertible is on the bottom hardtop on the top.
There is a "up" stop and a "down" stop. The 'up" is near your tube of goo.
Early models were different. hardtops and barracudas were pointy, convertibles were flat both these are 66 , barracuda on left, dart convertible on right. 67 and up looked the same to me, But I don't have a hardtop or convertible near me to double checkI thought the convertible vent frame was different from non convert. It is flat at the top vs more pointed? I have been wrong before!
