pishta
I know I'm right....
Older model with the progressive roller cam linkage. Missing both pump arms...and a rod clip? New shooters, Manual choke a little stiff. 30cc and 50cc pumps (bad). Needs some lube and probably need a gone through but I believe the gaskets are fine. Annular booster. Pics tell it all. If you see something is missing...it is. listed on E-pray for 165, $150 here for FABO. $20 shipped, paypal only unless I know you by your first name here.
