/6 I thought I posted on /6 page . My bad I guess .anyone know of a source for washer set for intake and exhaust manifolds?
Yeah, don't feel bad. I was thinking the same thing./6 I thought I posted on /6 page . My bad I guess .
OkStart a wanted ad. This thread is not one.
Hemi Performance (also Aus) has these. They note that they are flat. But I think these are closer to original shape and a few bucks cheaper. As long as they are around, I would rather have used originals though.The triangular washers are available new out of Australia: AS0190s Slant six Valiant steel manifold hold on batwing tabs | Aussiespeed Street & Racing Products Australia
Thanks for the info !Sources for new hardware:
I'm not sure if the conical washers for a small block V8 are the same as the center washer, but there are these from Mancini: Mancini Racing Exhaust Manifold Conical Washer
Flex-top locknuts: McMaster Carr has these. McMaster-Carr
Brass Washer - p/n 53010091 I don't know where to get them.
Do you happen to have the part number for the set?I got a complete NOS set from the Dodge dealership
Thanks!Before you install them, search for the post on slantsix.org showing how to orient. It is opposite the way intuition might suggest. If you install them backwards, the exhaust manifold may later crack.
