SS Lancer
How man offerings are suppliers offered 2x4 tunnel rams for the W2 heads ?
Thanks Chris
Thanks Chris
Good evening , I have a Pro Dominator Tunnel Ram , that has never been installed . If your interested .How man offerings are suppliers offered 2x4 tunnel rams for the W2 heads ?
Thanks Chris
Well, those are the only two I knew of.
MP-M1 TR and the Holley Pro Dominator
I haven’t actually seen anyone else make one. It would be interesting to see what pops up.
I wish
My current TR5 could be converted to fit W2 heads !
I wonder if anyone has ever attempted converting a standard port intake to work on W2 heads ??
Ok so enough material is there to mate to W2 cyl ports ???Yup. I did a six pack setup years ago for my w2.
I have debated going 2x4 tunnel ram for my w5s but I dont think it will fit under my hood very easily
WOW interesting
What I think you should do is get a set of W2 intake gaskets to put up on an intake and see what you can and can not do.
Intake bolt holes will have to be moved outwards as well. You'll see when you get the W2 gasket.
U are correct thank you and I hate to waste or ruin the TR5 Edelbrock I will try to just purchase proper one .Only W2 tunnelrams i can think of where Holley pro-dominator and MP M1 as has been said before.
Regarding the Edelbrock Tunnelram,i dont think there is enough meat in the runners of that intake to be able to match it to W2heads and if there is, enough i dont think there will be enough to get a nice funnelshape into the whole runner,you would proabably end up with a very straight and even port area from top to bottom,but only one way to find out and that is to measure them. and oh yeah if there is you will also have to drill for the different bolt pattern.
The aluminum ones are batten heads. Came out of Detroit in the 80s.
I think diamond also had some and probably from same core boxes.
Indy bought the Batt
Did some digging today and found my TR5 in the ( March 1, 1979 Direct Connection ) catalog wow look at the cover some Legends right there.That will make a kick *** street/strip set up.
Price is good.
I wonder if Indy has a tunnel ram for there set up. I’m sure a “Mod Man” is available.
No promoting here!Please do not promote that runnerless, massive plenum hunk of junk. J.Rob
