[Found!] 225 engine and bellhousing
moper
eastern CT
Looking for a running 225" engine, early flywheel, and early bell w/inspection cover. Not in a rush - engine needs to be earlier than '75, in running condition, and within a days drive of 06237. Bell/flywheel need to be '64-'65 or fit that chassis. Thanks in advance!
Edit - Also would consider entire early 225/3sp or 4spd package if you're swapping to V8. Only need the engine, trans, and bell/clutch. Not the full manual conversion...
Or possibly trading labor on anything for any parts.
If you’re only able to acquire individual parts periodically, I’ve got a slant flywheel from a 64 or 65
i was in long island new york yesterday
I have a Bellhousing and trans removed from 1964 Valiant if your interested. In NY on Long Island.
I have a bell/trans/flywheel from a 65 . In Eastern CT.
I have a fresh build 225. it is either a marine or industrial. It needs a valve cover and oil pan. I dented the valve cover moving it.
I'm just north of Buffalo.
There's only Canada just north of Buffalo!...lol. I'm about 8 hours east of Buffalo - still holding out for a more local solution. But thank you.
Go West young Man, Go West! We have the best chicken wings in the world, come try some and go home with a slant 6! It doesn't get any better than that!
Merry Christmas to all.
Chris
I have a slant I pulled from a 67 Coronet. Has a 3 speed bolted to it. It was full of oil & green anti freeze but I don’t know if it runs. I can get pics if interested.
Thanks guys. I've changed direction to use the stuff I have so I'll put up a new ad if/when I need something powertrain-wise.
